os .25 FX questions
Well, aren't the FX series ABC engines? If so, they should NOT be broken in rich. You can destroy their compression.
Don't know if it would affect it in the way you're describing though. Problems with transition from idle to full throttle is usually the low end needle. You might try leaning the low end a bit.
Dennis-
