BSE vs Cac
Would there be an advantage from either on of your motors in the 50 size for a pusher configuration? The BSE or the CAC? I will be putting this on a Nitro models bobcat, I know pusher's run hotter than your standard puller setups. So with that said, I would like this motor to last a long time so what brand of fuel would you recommend? Being a pusher do I need a higher oil content for your motor since it will be turning alot more RPM'S than I am used to? I currently use Omega 15% in all my glow motors.
On your pusher muffler since the exhaust port is moved up right beside the intake vs a rear exit is there any difference in performance between the 2 mufflers?
Do you carry your own brand glow plugs? if not what is the prefered plug for this motor?
