WARNING
I just want you guys to know that the ailerons and flaps on this bird are "pre-glued" from the factory.
Don't trust it! I gave a good tug like I always do on all ARF aircraft with pre-glued control surfaces, and the left aileron came out.
There was a very small trace of Epoxy on one of the nylon hinges, but the other 2 hinges wasn't even glued, the flaps and the other aileron seems to be glued in enough, when I tug on them they don't move.
So I suggest to everyone to check their pre-glued control surfaces. It's better to have them pull out on your build table than in the air, so give them a good tug.
Pete
