Will post up some pic's as I get more done. I have servos on order and a cowl coming also. I have more work to do as I am converting this to a electric power bird. I have a 500 watt motor on the way, so I need to do some mod's to the front for a battery compartment. I can't find to many areas to lighten up this build as it is simple in design. I need to figure out a way to dump some wgt. in the back as most converted gas planes turn out tail heavy. Yes I think the 2 servo's in the wing will be better might try and set them up to work as flaps. This is getting ahead of myself on that thought though. Glad you are a head of me on this I can learn from you.
John
