ORIGINAL: Oberst
...............Also I had to shim the Servo Mounts, they didn't seem high enough for the standard servo, resulting in one arm rubbing against the door. By adding the shims for the aileron servo's they are now more center.
Pete
Now that you mention it, I did the same thing (added 1/16" ply shims to the top of the servo mount rails). No big deal I guess it's better that they were too short than too tall.
As for the servo arms: I used normal length ones and put a slight bend in the steel control linkages to allow them clearance when the controls were at max deflection.
Will post pics of my retract mounts tonite
