Old 03-11-2010, 08:13 AM
mmn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM P47 Build
Hi
I've got about 5 flights on this thing now. The Aerovate 26cc engine is running in great. Got a 16x8 APC on it and it's got some nice thrust, good speed.
Couple of small probs:
[ul][*] I'm having some trouble with the muffler bolts coming loose. I've tried some red loctite and some of the red hi-temp Permatex gasket goo. One of the guys at our field has speculated that the bolts might be a couple of thousands off in size. I'm thinking of replacing the bolts with studs and using JB Weld or something to lock them in. Glad I made the cowl easy to get on and off. Anyone else having this problem and found a solution?
[*]One of the wheel wells shattered and blew out in flight. Hanging by the air tubing, I almost lost the plane due to the drag. I used silicone sealant on them in the build and they seemed real solid. I think I'm going to take them out and just sheet in and paint the wells. Took a piece of the covering cut out from the well to Home Depot and they matched the paint exactly.
[/ul]
Regards
-Michael
mmn is offline
