RE: Nitro Planes Hero 100 Version 2
The yellow on the fuselage was re-painted with Valspar Gloss White (102S) Spray Enamel paint. First, the black lines were masked off and then the yellow area was sanded with #220 grit sandpaper. I then taped paper towels over the rest of the fuselage before spraying.
A red line will be painted in the center between the two black lines. The color will be close to the red covering used to eliminate the remaining yellow on the control surfaces.
