RE: Whats The Right Servo?
If your vibration is excessive, you may want to check your engine needle valves for proper adjustment and balance your prop. I have had a Hitec HS-225 in my 33% Wildhare Extra 260 with a DA-85 for over 400 flights with no problems on the throttle servo.
