Tailhook notch
Well using CorsairJocks template I notched out the fuse. I had added an extra thickness of balsa inside before I mounted the horizontal stab but I still cut through this and had a hole in the fuse. I want to glass the fuse and to eliminate the hole I took 1/64 ply and glued it in then sanded to shape. Pete
