RE: Nitro engine won't turn over?
1 more problem, when i try to start it i don't see the fuel even attempting to move through the fuel line, i see a little airbubble that seems to be vibrating but no fuel is going INTO this carb, it just sits there , maybe since its not actually started it wont be sucking it through the fuel line? it doesnt look like fuel is even trying to get in there, and fuel line isnt pinned or anything it should be clear for movin, again blew out fuel lines no obstructions inside, and i turned the pin the fuel line is next to (going into the carb) 4 full turns from totally closed, so it should be open. any ideas?
