RE: Knowledge Quiz for Warbird wiz
What warbird am I describing?
First hint: It was flown by both opposing sides, in wartime, as well as serving in several neutral air forces.
Second hint: It was initially considered to be pretty much a failure; as its early models were clearly inferior to other designs produced by its host country. After use in combat, it was withdrawn as being unsatisfactory in performance. Only when redesigned, and assigned to a new role, did it prove successful.
Third hint: Both civilian and military versions were produced; and both versions were sold to, and produced by, other nations.
Fourth hint: Once the plane was redesigned, it was considered to be almost invulnerable.
Fifth hint: It served through two wars.
Sixth hint: It was in service for more than 20 years.
Thanks; Ernie P.
PS: You guys are 'way overthinking this thing. The third and fourth hints alone should put you close to the right answer. Tnx; EP
