PowerExpander EQ10 will not servo adjust
Hi,
I'm setting up a comp-arf 2.3m
2x servo on rudder, 1xservo on all other surfaces.
Using the EQ10, Power comes from a turbo reg and 2x2s Lipos.
The unit will reset in the options menu.
However when using the servo adjust menu nothing will work.
I have used a few of these units before, so i am familiar with how they work, but maybe i am missing something.
Not all of the servos are plugged in yet, but i don't think this will make any difference.
When i select "adjust servo A" function 1, and CH3 (Rudder servo), the LED goes out and the adjust bottons do not work.
Same for the throtle sevro when i try the same. (can't reverse this ch either)
(The LEDs flash as they should when doing the reset, and they come on as they should when the unit is powered up)
The reciever is bound, and they work with the radio as they should, i just can't adjust them.
Any help would be appreciated
