RE: Bob Cat Copy Falcon 120 Jet
Hey Fellow Falcon owners,
My EDF Falcon is ready for maiden.
Engine is a Tamjet TJ 100hp running on a pair of Hyperion 6s 5000mah batteries with a few degrees of down-thrust.
All up weight is 17.5 pounds.
Questions: How do you set your elevator? Should it be flush with the bottom of the horizontal stableizer?
Do you use the aileron, elevator, and flap throws suggested in the manual.... or a little more?
jim
