RE: NitroPlanes - MQ-9 REAPER
I started with the flap servo and cut out the provided plastic servo pocket cover. The manual photo
shows the servo glued into the servo pocket in the wing and then the cover is attached and held on
with 4 provided screws. I'm sure that would work just fine, but I felt more comfortable mounting the
servo to the cover as shown in the photos below.
First I marked the correct positionof the servo on the cover, thencut small pieces of 1/4 x 1/4" square
balsa stock and used some medium ZAP CA to glue them to the plastic cover. Then a little double
sided tape and the servo isheld in place.
