RE: Spektrum DX7 question
Guys, Don't be so hasty. It is true that you should not HAVE to rebind after the initial bind. BUT, If you have done any readjusting to your planes control surfaces, like new control horn positions, etc,etc, you should rebind. WHY?, because after you change anything on your plane, your radio only remembers the failsafe positions of the servos from before you made any changes. In most cases this probably is not going to be a problem if your changes are very minor. SOOO, what you were told is not bad advice.
Note Barracudahockeys' post where he state "UNLESS YOU MAKE CHANGES"
