ORIGINAL: rudder turns
I have converted and 6 other club members have converted there 8u,s and 9c Futaba radios to the Hitec 2.4 conversion,Works great,Tells you If your receiver battery is getting low, unbelievable range and you can't beat the price, Check It out,Thanks Ed/rudder turns.
Do you have to remove the antenna on a Futaba 9c radio when installing the Hitec module? Is there a little cable linked to the 2.4 antenna?
