RE: ESM Hawker Typhoon ARF build thread
Good tip on the retract bolts, Iam goung to turn one of the cylinders 180 deg as the side tube fittings are both on the same side which makes them exit the wheel wells at front and back instead of both front (or back which ever you want them to be).
I noticed the lack of invasion stripeson the gear doors, I will use covering or paint to match with the wings.
A question on CG, I read that the 100mm is good but is this with gear up or gear down ?, as the struts move backwards and forwards as they rertact, it may make a difference to the CG so what did you do ?
