RCU Forums - View Single Post - PST F-84G Build Thread
Old 05-18-2010, 03:41 AM
  #426
chrigui
Default RE: PST F-84G Build Thread
ORIGINAL: chrigui
i put some modify on my plane like Oliver indications.
i moved down the front gear system add 1cm lenght nose
i reduced the main diameter wheels from 115mm to 105mm
i modified original brake and cleaned it from grease ..
i removed 200g of ballast in the nose
then i will try to take off with 50% main tank full (like sm f-86 1/5 cg problem)
many thx for indication to Oliver and Chris
Hi Oliver
yesterday i tryed new modification in my f-84 to change the Ground AoA
50% less take off run lenght..... and not fast like previous flight..
