RCU Forums - View Single Post - NitroPlanes - MQ-9 REAPER
Old 06-06-2010, 06:54 PM
  #39
papajeff
papajeff's Avatar
Default RE: NitroPlanes - MQ-9 REAPER
I took a good look at the provided control rods and clevises and decided that they would be
more than adequate. I did, though, use asmall piece of fuel tubing to hold the clevisarms
together just to be safe. First, I attached the control rod to the servo armand thenpositioned
the middle control horn hole over the hinge line and marked the base holes. I used two screws
and a dab of ZapCA to attach the control horn to the moving surface.
ID:	1449102   Click image for larger version
ID:	1449103   Click image for larger version
