RE: ESM Hawker Typhoon ARF build thread
Some good info on the CG, too much data required on that link you posted though, I'm going with the 100mm as per the manual, the other forum on this plane shows that it flys good at this setting. I can play with it after it has flown a few times.
A couple more pictures, the spinner looks great and I got the cheap EMS pilot from Troy Built, looks pretty good too.
More later.
