The Enya is Fixed.....Well almost
Went flying today, took Enya powered Kaos 40 with new fueltank which is a better fit.
Tried a larger prop 12 x 6 ran a bit better flew it at 3/4 throttle still Dead sticking .......Hmm try adjusting the Idle/midrange mixture screw......*** [X(]
The retaining/lock nut is missing !!!!
Thanks Every one for all you help.
I wound the needle out and was able to get full throttle
I should be able to get things sorted once I find a new nut.
Johnkpap
