When does a shaved prop loose it's efficiency on speed?
so when will you know if you past that sweet part of the prop. The part where it goes from good to drag? What is an indication that you have gone way to far?
I was wondering because was curious as if it was a small thing or a big thing. The way it is now all my props seem to be about the same. See I was wondering if maybe there is an obvious way to tell on if you have shaved down so far as to where you can noticeably tell a difference about if you shaved to far?
Is this only on paper the difference or is it noticeable? Well besides spinning a whole load or rpm's and not going anywhere?
