E-flite F-86 Sabre 15 DF ARF
E-flite’s new [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFL8100#quickOverview]F-86 Sabre[/link] uses design principles that feature top-of-the-line glass and balsa construction techniques to recreate the famous jet fighter with extreme accuracy. In the jet arena where performance reigns supreme, this E-flite ducted fan jet hits on all cylinders with its performance - a fully designed intake and exhaust ducting. When outfitted with E-flite’s own Delta V fan and motor and a 4S Li-Po, the Sabre will hum with power and speed. As always, E-flite has gone above and beyond to fashion a model in which the aviation aficionado can take great pride.
Unlike many EDFs in its class that only provide aileron and elevator control, the F-86 Sabre 15 DF provides authoritative rudder control so you can execute point rolls and knife-edge flight with precision. The fan ducting has been designed to achieve superb efficiency without sacrificing a scale-looking intake or requiring the need for speed-robbing cheater holes. Swapping batteries and accessing electronics is easy with the generously proportioned magnetic hatch.
Specifications:[ul][*] Wingspan: 33.8 in (860mm)[*] Overall Length: 35.4 in (900mm)[*] Wing Area: 256 sq in (16.5 sq dm)[*] Flying Weight: 53 - 55 oz (1500 - 1560 g)[*] Motor Size: 15 DF 3200Kv Brushless Motor[*] Radio: 4+ channels[*] Servos: Sub Micro (4 required) & Micro (1 required)[*] Speed Control : 60-amp brushless[*] Recommended Battery: 4s 14.8V 3200-3300mAh Li-Po[*] Scale: Warbird[*] Experience Level: Advanced[/ul]
Features:[ul][*] Designed for the E-flite Delta V 15 DF for great power and performance[*] Lightweight fiberglass fuselage provides minimum weight to this accurately detailed scale model[*] Factory-finished scale trim scheme with 3 unique nose art/squadron decal sets included[*] Magnetic battery hatch allows for quick access to the airplane's electronics[*] Hyper-efficient ducting with no "cheater" holes[*] Airfoil-shaped vertical fin and rudder[*] Full 4-channel control[/ul]
