RE: ESM P47 Build
Did not add any extra right thrust, Should i.
Engine standoffs were from dle50 and i cut off about 1/4 inch.
also used 3 thin washers on all 4 standoffs to get motor to where i wanted it.
Guess i could correct with rudder if i need a little more right thrust.
What did you do. And did you happen to notice that the down pitch is a bit much.
Whats your take on it !!!!
