Old 06-18-2010, 01:34 AM
  #50
P47Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM P47 Build
This will have to be a bit of trial and error, but I would suggest adding in perhaps 2mm to begin with (left engine mounts) and see how it behaves. If it is practical, add more right thrust later. In my view, no extra downward pitch is required. I add my right rudder manually as the flying goes, I did not mix in any right rudder with the throttle, although thiswill also work well. I am thinking of experimenting a little with that now. Winter project will be to glass the firewall and pull off some lead. This plane holds up well to vibrations, and shows little sign of wear andtear after 80 flights. So I guess I'll keep it for a few more seasons and try a few adjustmenst here and there to optimize flight characteristics.
P47Pilot is offline
