RE: Is my pump bad?
Go to your menu and put the line going to the turbine into a large cup. Using the prime function, it should slowly start out and then go into a nice steady stream.
Where are your airbubbles at, before, after the pump?
If you are getting bubbles not before, but after the pump then I would say you have some type of airleak in the pump.
