will i burn my motors /ecs with this battery
can I use the below battery based on the specs at the bottom of this post
Capacity: 2200mAh
Constant discharge: 20C
Burst rate: 30C (15sec)
Configuration : 4S 14.8v
Pack size: 113x34x33
Weight : 247g
can I use the above battery with the following plane/specs
Motor: 2 x 30-XX Brushless outrunner 3900kv
ESC: 2x20A
Duct fan: 2 X 75mm
Required:
11.1V 2200mah 3S 25C Lipo
