RE: ARG! Control Surface Horns - Help
You can make your own control horns out of plywood... knotch the control surface for some 3/32 plywood, cut and shape your horn and epoxy in place.
Or, who says you have to use the holes that are already in the horns? Move the horn to where it should be then drill your own holes.
