RE: Warning: RCGF 45 Owners!
I'm waiting to see how the prop shaft extension works out. With the stuff they sent me you could not determine which adapter you were going to need. Square base or round base. Your engine could be cut for a square base but be installed or shipped with a round base that could not fit correctly. I see they are still having trouble drilling prop washers with the correctly sized hole for the screw diameter used.
Good luck BP. You're going to need it. I don't know how you figure you foks will be able to correct a manufacturer attitude towards the customer.
I wish you all the success you can obtain, and all the profitability possible under the circumstances. Hopefully none of the engines ever come apart and cause physical harm to someone in America. If and when that happens you and one or two other U.S. distributors will be the ones paying for 100% of the liability claims. I doubt you'd be able to connect a phone call to the manufacturer in that event.
