Mount the engine and then put on the carb...?
And how do you reach in there to tighten the screw? I couldn't reach it, no matter what... Mine came loose when I started the engine up the first time, and I had to cut a small notch out of the fuse side to be able to tighten it without removing the engine...
I now have a sturdy one piece engine mount in there and I used self tapping Parker screws to hold the engine down... I should have done it this way the first time around... much simpler... and the engine doesn't vibrate loose anymore...
The only drawback is that the wiring in my servos vibrates loose now...
