RE: Perry Pumps and regulators
My new Venus II has a pretty bad trim change from full to low fuel, so I decided to re-locate the tank to the CG. I bought a Perry pump. My OS120AX has a very nice boss in the middle of the backplate for the preassure fitting. My question is about the fuel tank vent. As this is an aerobatic airplane I will be flying upside ndown and all over the place. Is there a vent configuration that prevents fuel from exiting the tank through the vent. I was told that they make a plug for fuel vent lines that has a very small opening that will allow air to enter but is too small for any significant amount of fuel to escape through. If I use that type of plug with a bleed hole, I would surely need to remove it when fueling so the fuel, when full, has a way of discharging.
