DX7 Binding issues with eletric plane
new to Dx7 & eletric but not to rc and having some problems with my Dx7 .
I succesfully bound my model at home 55" span plane -2200 lipo .
So the procedure as explaned to me due to the eletric nature -after is was successfully bound
1)at field turn on radio
2)plug in lipo battery to power plane
3)plane should be bound ...
It seems that I have to unplug the lipo , and turn off the radio about 3 to 4 times to get it to bind at the field ???
I am missing something ? do I need to press the bind button on the back of the plane when turning it on at the field the plug the battery into the plane .
If I plug the lipo in first , I could have dangerous results where a signal hit the plane and start the throttle ect , so I always turn on transmitter first .
again wierd because its takes about 3 or4 attempts to get it in bind mode.
Also when done flying perhaps the clue is in my method of shutting the plane down I land , disconnect the power battery to the plane then turn the radio off would that confuse the receiver
