RE: BOOMERANG ELAN - New Build & Setup Thread!
Goose,
Actually with the new bottles from Dreamworks the trick of sliding them in through the intakes doesn't work. I figured it out and they are both fitting nicely.
I posted photos of the battery attached aft.
I added 1/2 inch to the nose gear and used wood screws for the mains.
I'm not sure what you meant about the vent. Do you mean the tank vent? I'd like to run that sucker out of a port in the bottom of the fuse.
