RE: BOOMERANG ELAN - New Build & Setup Thread!
If you run the tank vent out of the bottom do ensure the end of the tube points forward or you have a angle cut on the tube pointing forward, or the tube is long enough to point backwards in flight as straight vertical tubes will vent fuel over the nice new white underside and turn it yellow, lots of disscusion on this elsewhere.
Mike
