RE: OS Max 60 FP Not Running
The head is not hurt that bad & will still work. Put a prop on the crank,take a heat gun or lpg torch & heat the case area around the fins ,hold it in your hand with a glove on or a large rag,drop a plug washer down the cylinder with the piston at the bottom of the stroke & catch the edge of it in the exhaust opening of the sleeve & turn the engine backwards & the sleeve will come out . To me it is installed wrong but you will be able to see where the pin is located ,just put the notch over it when you put it back together .
Don't give all eBay engines a bad name ,I have sold over a 1000 of them & NO bad feedbacks. Get the sleeve in right & it will run . Check the head again for the gasket , use a x-acto knife blade in one of the head bolt holes & pry up a little,they are hard to see sometimes .The thrust washer is there to keep the drive washer from gauling when you use a electric starter,you should get one.
Hang in there & will make a engine man of you yet ! Max H.
