ORIGINAL: KamikazeParanoia
Thats the thing with the killerbee, I dont mind not having the kill switch on channel 3 (can just turn the TX off if I need to), im thinking I will need channel 3 for the disk brakes?
Can disk brakes (and the standard rear brake) be operated with a two channel radio? (if the third is taken by the kill switch)
You can even use the KillerBee on a two channel radio, you just turn off the radio to kill the engine instead of operate the KB from the third channel. Hope you understand. And yes, go for the Futaba radio, you get sooo much more than just the label.
