ORIGINAL: Jgilk1
i guess i have to chime in here....
you have 2 steering servos (which we all know pull a **** tone of power) the stock spectrum receiver only pulls 4.8v @ we will say 100kv respectably... this is not good i cant say whether the stock steering servos are good or not (haven't had the money to pick up a mt yet hopefully for my birthday or so says the gf)
but in a car audio setup if a sub woofer says minimum it requires 700w rms and you try to power it with 400s rms (under power) your going to blow the high end out of the subwoofer and thus why your setting your receiver on fire and burning up the steering servos... imho
pulling that much load through a receiver was never intended
which as discussed before you run the servos of a y-harness so you do power the servos straight from the battery
