Remote Glow Starter queston
I recently purchased a used plane that had a remote glow starter mounted in it. The problem is, is that the wires were clipped in it. I did get the other end of it (that hooks up to the glow plug) but it only has one wire (yellow) that is mounted to the top of the cap. The part that is mounted on the side of the plane has a yellow wire and a black wire (I assume this is the ground) hooked to it. The only place that I can see to hook this black wire to is to solder it on the side of the cap that hooks to the glow plug (this cap is what has the yellow wire coming out the top). Am I correct in that I need to solder this black wire to the side of the cap? I appreciate any direction on this issue! Thanks!
Trent
