ORIGINAL: ChuckW
It is likely just an adhesive decal and you can probably peel it off if you are careful then replace it with any good vinyl decal for your choice. If you are really lucky, the decals won't even be applied, they might just be on a sheet in the box.
Is this your first airplane?
Yes, this is my first plane. I'm hoping not to remove the lettering by nose diving into the ground....
I'm pretty sure they are on the kit already...maybe a hair dryer will do the trick.
Thanks for the help!
