Servo Strength's
I have been told that with the radio on you should not be able to move the elevators up or down and if you can you have week servos, with the bird static and radio on every thing is good
I am using hs 645 mg, 1 on each elv, 6 volt 2300mah pack all heay duty wiring and switches Now with the engine running you will get some defeliction up and down both sides.
The bird flies, but is vary sensitive in pitch, Which brings the question why ?
also I have about 50% expo on the elv's
thanks in advance for your thoughts
Cheers Bob T
