RE: fuel tank at balance point/center of gravity
It actually doesn't add THAT much weight to the nose, but you are correct.
Many people who use gasoline engines or YS brand engines DO put the tank on the CG because those engines have built in pumps.
Putting it back there without a pump can result in lean runs on a climb (unless you care to add a pump)
