RE: Spring Air Retract Identification
You are going to need an air valve, air tank, fill valve and tubing. The valve needs to be one that has only one port as the gears are spring loaded down and need air to hold them up. From reading the boards here on RCU, Spring Air does awnser questions, but it can take a while. You can use Robart air tanks and fill valves as well as tubing. You can also use the control valve that they make for their air up retracts. Good Luck, Dave
