RCU Forums - View Single Post - New plane is here!! Question on engine cover?
Old 08-27-2010, 11:10 PM
ChuckW
ChuckW's Avatar
Default RE: New plane is here!! Question on engine cover?
The names these Chinese companies give their airplanes crack me up sometimes. So does some of the stuff they put in their instructions.
I absolutely would not glue the cowl. You will likely need to remove it at some point. Use small screws (if there is something in the fuselage for them to bite into), strong tape or magnets that will allow you to remove the cowl.
