RE: Throttle flutter with motor running, radio on
Either put a plastic clevis onto the end of a metal threaded rod to connect throttle arm or make sure there is no intermittent connection between 'Z'- bend causing the interference, i.e. a ground strap needed from throttle arm to 'Z'-bend.
