RE: Spark Plug Cap Assembly Procedure
NM2K,
The wire can be inserted into the spring and be captured by it. That method is used in another type of ignition, similar in design, with no problems. Using that method you must be assured the urethane cap has no breaks that would permit the charge to arc over the inner boot to the outer cap.
