Berg 5 will JR Crystal work in it OK
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Berg 5 will JR Crystal work in it OK
Page: [1]
Login
Berg 5 will JR Crystal work in it OK - 1/13/2005 3:06 AM
Dennis Tampa FL
Score: 100
Last Login: 12/26/2008
Status: offline
My LHS put a JR Crystal in the Berg 5 they sold me. I then see on the RC-Direct website that to use only Berg Crystals.
Do you think this is going to be OK JR crystal in Berg Reciever???
Thanks in advance, Dennis
_____________________________
DENNIS
Hide Signatures
       Post #: 1
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 3:20 AM
mglavin
Score: 100
Last Login: 6/15/2009
Status: offline
I don't think it will work. For the most part crystals are not inter-changeble from one OEM to another, however there are exceptions.
Simply try it and see, either it works or it don't. If it appears to work be sure and perform a rigorous range check to validate the integrity of the radio link.
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
Hide Signatures
(in reply to Dennis Tampa FL)
       Post #: 2
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 5:09 AM
laryboy
Score: 100
Last Login: 6/6/2009
Status: offline
both berg and jr are both single conversion receivers therefor the jr xtal will work in the berg
Hide Signatures
       Post #: 3
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 5:21 AM
mglavin
Score: 100
Status: offline
quote:
ORIGINAL: laryboy
Not true... OEM specifications for crystals are typically different. If memory serves me the oscillator frequency plays a factor. Its simply is not a gimme single conversion to single conversion application. As I noted previously there are exceptions to the rule.
Michael Glavin
Hide Signatures
(in reply to laryboy)
       Post #: 4
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 2:04 PM
laryboy
Score: 100
Status: offline
who caes if OEM's might have different specs. what nonsense. does not a hitec xtal work in a futaba receiver ? i know that the jr xtal will work in the berg 5 because i researched it. the berg 5 is also shift selectable. if you know a make of xtals that wont work in the berg 5 then please post.
Hide Signatures
(in reply to mglavin)
       Post #: 5
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 3:49 PM
mglavin
Score: 100
Status: offline
As I mentioned there are exceptions to the rule. And yes Hitec and Futaba dual conversion crystals do work together or are backwards compatible. However this is not sanctioned by either manufacturer.
Do you have personnel knowledge of the JR single conversion crystals working in the Berg RX? Not research?
Michael Glavin
Hide Signatures
       Post #: 6
RE: Berg 5 will JR Crystal work in it OK - 1/13/2005 7:10 PM
mr.rc-cam
Score: 100
Last Login: 7/1/2009
Status: offline
The JR Xtal seems to work fine in the Berg DSP5. But if you try it, it is wise to perform extensive range testing.
The caution about freely mixing Xtal brands is a good one. There is no common spec for the Xtals (the Xtal vendor builds to order). Besides the obvious issues concerning xtal lead and body size (some xtals have very skinny leads that won't make good contact in a Rx that need the bigger lead size), they also vary in native frequency, overtone mode, and capacitance. For example, if the capacitance spec is slightly different, the Rx's local oscillator may not startup reliably or could operate a tad off frequency. Those are not good things. It is best to consult with the radio maker. In the case of Berg's Rxs, Peter will be honest about using JR xtals in his products. Ask him directly.
RC-CAM
Best Regards,
Mr. RC-CAM
Hide Signatures
       Post #: 7
RE: Berg 5 will JR Crystal work in it OK - 1/14/2005 3:48 AM
fiery
Score: 100
Last Login: 7/3/2009
Status: offline
I bought a Schulze Alpha 8 8 channel receiver recently.
It was supplied with a JR single conversion crystal. The vendor is a reputable supplier and would not
provide a crystal which was not suitable.
That said, the instructions warned against using non-schulze crystals, as they all do.
Schulze are linked to Berg. I think they may assemble his receivers but I am unsure. They may even share circuitry and components. Can anyone advise on this?
I feel certain that the JR crystal will perform fine.
fiery
Hide Signatures
(in reply to mr.rc-cam)
       Post #: 8
RE: Berg 5 will JR Crystal work in it OK - 1/14/2005 5:49 AM
mr.rc-cam
Score: 100
Status: offline
Per Peter Berg: Schulze's license to manufacture Berg-designed receivers has been terminated as of September 2004.
Berg is now a part of Castle Creations. I would expect that they will be manufacturing the Berg designs in the near future.
As far as using a JR Xtal in a Berg, it would be very easy to just ask Peter. No doubt he will say it is fine, but why not get this sort of info directly from him? He designed the product. He may be reached at info*AT*bergent.net (replace *AT* with @).
Best Regards,
Mr. RC-CAM
Hide Signatures
(in reply to fiery)
       Post #: 9
RE: Berg 5 will JR Crystal work in it OK - 1/14/2005 11:54 PM
lrb75
Score: 100
Last Login: 7/4/2009
Status: offline
They recommend their own crystals but I have flown one of the berg 6ch receivers with a JR crystal. I would do a good range check before flying but don't you do that before every flying session anyway?
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.895RCU1
