LiPo Fatality    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> LiPo Fatality
Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
LiPo Fatality - 12/8/2004 9:28 PM
bdavison
Score: 105
Last Login: 9/28/2010
Status: offline
Well, I was flying my shockflyer outside, and doing inverted spins. I pulled out at the bottom, hit full throttle, and nothing happened.
No thrust means no flying, so it just settled down in the top of a tree.
Well, I couldnt get it down, because I had to go to work.
I came back that evening, and luckily the plane had came down out of the tree.
I figured the LiPo would be toast. I was right.
My poor LiPo died a most horrible death, as its life was sucked out leaving only 3V left out of its 3cells. I tried resusitation with the triton charger, but to no avail. She shall never fly again.
My question now is...how do I dispose of this battery. I dont want to throw this volatile thing into the trash, and watch as the garbage truck explodes. I dont want to bury it because of leakage of the caustic chemicals.
What shall I do?
Hide Signatures
       Post #: 1
RE: LiPo Fatality - 12/8/2004 9:36 PM
msm9724
Score: 100
Last Login: 3/8/2008
Status: offline
You should put it in a container with salt and water and leave it in there for some time.
Hide Signatures
(in reply to bdavison)
       Post #: 2
RE: LiPo Fatality - 12/8/2004 9:38 PM
Baron UK
Score: 100
Last Login: 10/28/2007
Status: offline
Yep in salt water.
< Message edited by Baron UK -- 12/9/2004 12:20 PM >
Hide Signatures
(in reply to msm9724)
       Post #: 3
RE: LiPo Fatality - 12/8/2004 9:47 PM
Matt Kirsch
Score: 105
Last Login: 1/5/2012
Status: offline
NO! Do NOT pierce the cell before the soak! There have been instances where the cell has been punctured for disposal that have resulted in a fire. Puncturing the cells creates a direct internal short.
The salt water will conduct enough electricity that the cells will slowly discharge. Just leave it in the solution until it stops bubbling.
Hide Signatures
(in reply to Baron UK)
       Post #: 4
RE: LiPo Fatality - 12/8/2004 9:50 PM
cwrr5
Score: 100
Last Login: 2/6/2012
Status: offline
Garbage truck explode? It's not dynamite! hehehe!
Discharge the cell/pack to 2.5 volts(or less) per cell, soak in a suitable container filled with saltwater(get as much salt in as you can) for 24 hours or so, make sure the voltage is 0 volts after soaking, then throw it in the trash. Don't worry bout the chemicals - they'll be taken care of.
Edit: Just like Matt said - DO NOT PIERCE THE CASE!!! Just drop the whole thing in.
_____________________________
Arizona Aero Models
www.azaeromodels.com
Hide Signatures
       Post #: 5
RE: LiPo Fatality - 12/8/2004 11:13 PM
MUSIC PUBLISHER
Score: 102
Last Login: 12/4/2007
Status: offline
Holly comoly..these lipos are something else..they sound more dangerous then spent radioactive fuel rods...I know they are suppose to be the greatest thing around..but they dont seem like something id want to get involved with..at least until the technology improves even more..however long that may take...P.s..we have a nuclear waste faciltiy 3 miles from my home{maybe this explains my lack of mental capacity} ..if the saltwater doesnt work..mail them to me..and ill discard them..LOL...
Hide Signatures
(in reply to cwrr5)
       Post #: 6
RE: LiPo Fatality - 12/9/2004 12:11 AM
cwrr5
Score: 100
Status: offline
hehehe! They're not THAT bad! Hmmm..... nucular powrd plaines......
Arizona Aero Models
Hide Signatures
(in reply to MUSIC PUBLISHER)
       Post #: 7
RE: LiPo Fatality - 12/9/2004 3:35 AM
Leety
Score: 100
Last Login: 9/4/2008
Status: offline
how do you discharge a pack to less than 2.5v, if the charger you use doesn't have a discharge feature?
Aero-Works Edge .60/.90 / OS 1.08
SIG Somethin' Extra / Thunder Tigre .46
Hide Signatures
(in reply to cwrr5)
       Post #: 8
RE: LiPo Fatality - 12/9/2004 4:08 AM
jakjr
Score: 100
Last Login: 10/28/2009
Status: offline
Connect it directly to a small (like 370 size or smaller) motor and just let it run until the motor stops.
For some reason, I was execting to read about somone getting killed by a li-po pack
< Message edited by jakjr -- 12/9/2004 9:18 AM >
{o,o}
|)__)
Hide Signatures
(in reply to Leety)
       Post #: 9
RE: LiPo Fatality - 12/9/2004 7:18 AM
MUSIC PUBLISHER
Score: 102
Status: offline
I think all lipos should come with a "complimentary" radiation suit and mask...LOL..jus teasin...
Hide Signatures
(in reply to jakjr)
       Post #: 10
RE: LiPo Fatality - 12/9/2004 6:29 PM
Rhilluk
Score: 100
Last Login: 2/20/2011
Status: offline
quote:
ORIGINAL: jakjr
I was too
Hide Signatures
(in reply to jakjr)
       Post #: 11
RE: LiPo Fatality - 12/9/2004 8:35 PM
Shahid
Score: 100
Last Login: 2/4/2012
Status: offline
same here
Fly hard, but crash gracefully
Hide Signatures
(in reply to Rhilluk)
       Post #: 12
RE: LiPo Fatality - 12/10/2004 12:31 AM
typicalaimster
Score: 100
Last Login: 12/3/2010
Status: offline
Yeah I thought the Lipo pack exploded and caught the plane on fire! I was disapointed.
Hide Signatures
(in reply to Shahid)
       Post #: 13
RE: LiPo Fatality - 12/10/2004 7:42 PM
xplayer930
Score: 100
Last Login: 1/21/2011
Status: offline
i use LiPos in my foamies, you guys stress WAYYYY to much! Your forgetting that our cell phones run on a LiPo and we carry those in our pockets. Dont worry so much and enjoy the hobby
Hide Signatures
(in reply to typicalaimster)
       Post #: 14
RE: LiPo Fatality - 12/11/2004 3:13 AM
bdavison
Score: 105
Status: offline
HAHAHAHA,
Yeah, sorry to disappoint everyone, but no one died from my small LiPo tragedy. Although I think my pocket book suffered an anurism when it found out it had to replace it.
Hide Signatures
(in reply to xplayer930)
       Post #: 15
RE: LiPo Fatality - 12/11/2004 4:06 AM
Rhilluk
Score: 100
Status: offline
Thats one thing I find very difficult to accept about lipo. When nicads first came out, they would explode if not charged properly. I remember exploding them in the physics lab by running a high voltage through them backwards.
I saw a guy at a field saying how he didn't want anything to do with lipo's, they were too dangeous, they might explode or catch fire.
The thing is he was telling me all of this while he was fueling up his DA 50 powered extra with a FAG in his gob. Now I couldn't get my head round this.
Hide Signatures
       Post #: 16
RE: LiPo Fatality - 12/11/2004 4:18 AM
cwrr5
Score: 100
Status: offline
"Yeah I thought the Lipo pack exploded and caught the plane on fire! I was disapointed."
I'll see what I can "arrange" when I get home.... Honestly, thats what I was thinking too when I saw the post. hehehe!
Arizona Aero Models
Hide Signatures
       Post #: 17
RE: LiPo Fatality - 12/11/2004 10:08 PM
cloudancer03
Score: 121
Last Login: 1/31/2012
Status: offline
these batteries are relatively safe..hummm what about nuclearbattery.lol ..I never respected anyting more than li -po batteries.I saw what happened to one at last years neat event..the flames shot out from the guy's station wagon at 2 feet.man o man that will get your attention..
I wont leave them out in the open they are stored in a metal tin box and I wont charge them in my workshop and walk away as my house is all paid for..I am joking a bit but when someone says oh just puncture the cell eeeeeeeegaaaaaddddd. salt water huh just heard that this fall and ingenious and so simple..
Hide Signatures
(in reply to cwrr5)
       Post #: 18
RE: LiPo Fatality - 12/13/2004 5:29 AM
xplayer930
Score: 100
Status: offline
When i bought my first LiPo my dad wasnt to happy about it cuz he worries as soon as i crash the pack is gonna blow up. My mom worries that im gonna burn down the house. I NEVER leave the LiPos unattended to.
Hide Signatures
(in reply to cloudancer03)
       Post #: 19
RE: LiPo Fatality - 12/13/2004 6:10 AM
bdavison
Score: 105
Status: offline
The LiPo's are safe as long as you use them correctly. Im ashamed to admit it, but I've put some of mine through the worst possible scenarios. Dropped them, flew one into a pond (still have it and it still works fine), countless crashes, etc. As far as I can tell, the only way to get one to blow up, is by charging it incorrectly.
Ive never had one explode. Knock on wood.
I keep mine in a old Ammo can, and charge them in it too. Been thinking about that battery bunker thing, but havent bought one yet.
Hide Signatures
       Post #: 20
RE: LiPo Fatality - 12/14/2004 9:22 AM
crashawk
Score: 100
Status: offline
<As far as I can tell, the only way to get one to blow up, is by charging it incorrectly. >
yep done that, only it was a hard case li-ion pack. had 2 packs sitting in a coffee cup, both being charged by different chargers. cell phone rang and I answered it and went into the house to talk to my dad. after about 25 minutes I heard what sounded like a rocket going off in the garage. I was lucky, cell vented and rocketed across my garage in the oppisite direction of a large box of balsa wood, the other cell in the pack was still venting flames about 12 inches when I walked in the garage but it was facing down so didn't go anywhere. good thing they were cheap packs. turned out the mk2 charger I got from a friend didn't have the instructions so I didn't know you had to push the button 3 times for lithium packs. my fault. now I only charge under supervision, if I leave the garage I unplug the pack and I have a fire extingesher handy.
they are still safe if you follow the rules and use some common sense.
I thought maybe someone had died when I saw the title, is that bad?
Jason
My freinds call me Duh!
Hide Signatures
       Post #: 21
RE: LiPo Fatality - 12/14/2004 5:52 PM
RCFlyer55
Score: 100
Last Login: 10/28/2011
Status: offline
Foofydoo,
A fag in his gop, that makes me want to move to the UK just to be able to say that and not have everyone here in the US look at me like I have 3 heads.
Hide Signatures
(in reply to crashawk)
       Post #: 22
RE: LiPo Fatality - 12/14/2004 5:53 PM
RCFlyer55
Score: 100
Status: offline
I charge mine in a fire safe box I bought on sale for $20. from office Max. BTW I also store them in there, not in the plane.
Hide Signatures
(in reply to RCFlyer55)
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
2.297RCU1
