No BS Batteries
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Composite-ARF Yak-55SP 3.3m
Seller:  Edbaker
Details:   $6,500.00   |  10/14/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> No BS Batteries
Page: [1]
Login
No BS Batteries - 9/28/2004 1:32 AM
Red Scholefield
Score: 179
Last Login: 9/27/2009
Status: offline
I had a chance to look at these packs. No BS Batteries is owned by Steve Anthony who worked for S&R as the head shop guy.
No BS Battery Analysis
Transmitter Pack 8 cell Sanyo 800 AA 2 X 2 X 2 config. Date code IA (Jan 04)
Receiver Pack 4 cell Sanyo 800 AA Flat pack Date code IA (Jan 04)
Receiver pack had 20 mil over sleeve (most manufacturers use 6 mil). Lead wires 8” long awg 20 wire (most manufacturers use 4-6” long w/awg 22 –24). Futaba J connector w/gold flashed pins. Stress relief on lead provided by 1” filament/strapping tape. Weight 101.2 grams vs. 88.1 grams for Futaba 4 cell AA 700 mAh pack. Cell interconnections .187” X .005” thick nickel straps triple welded (Futaba packs double welded Ni-plated steel – some other pack assemblers use .158” wide tabs). See photo. Pack voltage as received 4.48 volts suggesting unformed cells. (Sample not selected for this test). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 991 mAh to 3.6 volt cut off (123% of rated capacity).
Transmitter pack OCV as received 8.34 volts (unformed cells). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 969 mAh to 7.2 volt cut off (121% of rated capacity). Pack over sleeve 6 mil (standard for transmitter packs). Leads awg 22 wire with Futaba J connector w/ gold flash pins. Interconnecting straps.187 X .005, triple welded, cell sticks connected by folded tab. Fiber insulation plate used on each end of pack.
Discussion: The No BS receiver pack employs heavy-duty construction that is as good as I have ever seen. The techniques used result in an overall lower pack resistance than packs using the same cells from other cell assemblers as well as a pack that is more resistant to shock and vibration seen in the R/C aircraft environment. Transmitter packs while essentially the same type of construction as other pack providers are of top quality assembly.
One each of each type tested. Test device – Alpha 4.
Notation for attached picture.
Pack welding.
Futaba pack at top
No BS pack at bottom
Red’s R/C Battery Clinic
9/25/04
Click to see fullsize image.
Click for fullsize
< Message edited by Red Scholefield -- 9/28/2004 1:37 AM >
_____________________________
Red S "AMA 951 since 1958
www.hangtimes.com/redsbatteryclinic.html
Hide Signatures
       Post #: 1
RE: No BS Batteries - 9/28/2004 3:32 PM
Lee Belew
Score: 100
Last Login: 12/5/2005
Status: offline
Red
I for one want to thank you for this information. This is probably the best info I have seen reported on battery packs that are available for purchase. I have worked with this type of things for approx. 35 years and I really do think you for your information for us flyers expecially us seniors.
Lee Belew
Hide Signatures
(in reply to Red Scholefield)
       Post #: 2
RE: No BS Batteries - 9/28/2004 6:03 PM
Hangtime
Score: 100
Last Login: 9/14/2009
Status: offline
Red, my humble thanks for your review!
So that folks may find us on the web or locate forum discussions mentioning our packs try also NoBS (without a space) Batteries, and our website home is at www.hangtimes.com
Thanks again for the analysis!
Steve Anthony
www.hangtimes.com
NoBS Batteries
Hide Signatures
       Post #: 3
RE: No BS Batteries - 10/1/2004 11:57 AM
DBCherry
Score: 106
Last Login: 10/25/2009
Status: offline
Thanks from me as well Red.
I place a lot of faith in your assesments and your advice in general. I use to follow your columns when you wrote for whatever that magazine was. (The one that I dropped my subscription to during all that controversy.)
I for one will be buying my next packs from No BS.
Dennis-
He who dies with the most toys is, none the less, still dead.
Hide Signatures
(in reply to Hangtime)
       Post #: 4
RE: No BS Batteries - 10/1/2004 12:46 PM
vicman
Score: 137
Last Login: 11/7/2009
Status: offline
I picked up a few packs from him at Joe Nall. He made them up just for me right on the spot and they are doing a great job. Steve also spent some time with me discussing charging and chargers and gave some great advice. After my time spent with him I have much more confidence on how to accurately charge my batteries.
Thanks for a great product and friendly service!
PS. did you ever get the Dymond ST instructions I sent?
Vic in NC
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to DBCherry)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
