GoPro and Quad AP
GoPro and Quad AP
I'm hoping to build a multi-copter to carry a DSLR, in the meantime I've been practicing with a Quad and GoPro:
http://www.vimeo.com/23570784
http://www.vimeo.com/23074543
http://www.vimeo.com/22983383
http://www.vimeo.com/18859201
RE: GoPro and Quad AP
Chuck, do you have you camera mount on the top or the bottom of you Gaui?? If you have it on the bottom which mount do you use?? I saw you video the collecting memories.. WOW!!! What program did you use?? Again you you did an awesome job. Thanks for sharing.
Mike
Mike
Loved your Videos ! I am new to Quads and have a SM450 V2 I got from RC Timer... I have mounted a key Fob Camera on the lower Plate using a piece of moderate density foam as a spacer, hoping to eliminate vibration... but I'm still getting the Jello Effect and the camera cuts out after a minute... I have run the camera back in the house and it records till I shut it off... I'm using 3 Bladed Props right out of the bag... and a NAZA Controller. The Quad is rock steady visually... Any thoughts on how to identify and eliminate and or isolate the camera from the vibration ?
Any help or suggestions would be appreciated... Thanks.
Charlie
Charlie
