New onboard videoS
RE: New onboard videoS
Can you try positioning the camera differently. The constant Panning effect is difficult to understand. That camera setup is quite small. I can invision many ways to use that product. You should try mounting it on a pylon facing forward above the fus. I have been working on many different kinds of mounts, but I ran out of Summer time testing temperatures up here in Wisconsin.
Rj
Rj
VA
Hi Vova,
I think the quality is really good. What software are you using to transfer the video to PC? also, is that a standard 400 mW set-up with standard antennas and running from a 9 volt battery? I will also like to see the camera positioned facing forward a bit.
Keep up the good work!
ORIGINAL: Flying_Luigi
Hi Vova,
Hi Vova,
Thanks.
Im using a happauge(sp?) video tuner card that I bought used for 23.00 and the free downloadable microsoft movie works to make the video.
The system is a "stock" 400mw system, no mods.
I have some more video of the camera facing forward.
NOw on to make video...
-Vova
